Loose date wheel?
Have you worked on a watch movement before? The general approach is to take it apart to see where the problem lies. If you care about this watch it would be better that you give the job to a professional instead of trying yourself.
Thanks for your reply! However, it will probably cost me more to send it for repair than buying a new movement... ill play a bit with it and if I screw it up, ill buy a new one
Sent from my EVA-AL10 using Tapatalk
That is a "Watchuseek Chinese Mechanical Watch Forum Moonphase limited edition", based on a Seagull ST25 mov.t. It is not a cheap watch.
It could be possible to repair it even without access to spare parts, but once again, if you want to give your nice watch a chance to survive, please do not try yourself.
Edited by jdm
