Here is a real beautiful clock
oldhippy
Here is a real beautiful clock made in England and it made its way to the U S A. It’s had its repairs but it’s a cracker, the dial looks as if it’s from a Longcase Clock but this is original. Plenty of photos so you can see the works and what goes on behind the dial.  Note how thin the steel work is for the wheels and the finish on parts, a sign of a good craftsman. A fine clock for anyone’s collection.
http://www.ebay.co.uk/itm/1840s-Striking-Fusee-Bracket-Clock-sold-in-Philadelphia-by-John-L-Lawson-/232343376052?hash=item3618be90b4:g:L6UAAOSw8lpZILtp
It is a very nice clock but must be somewhat of an odditty, to have a English made clock made specifically for the American market The seller states its from the 1840's what are your thought on the dating of the clock to me it looks to be from the early 1800's, An intresting feature of the painted dial is that the ship appears to be flying a Colonial ensign maybe a little dig by the dial painter that America was once a colonie ?
It all fits in nicely about age, the name on the back of the dial gives the game away because the seller has given the history of when they were making dials and false plates for Longcase clocks.It is excepted to have a span of 5 to 7 years ether way in dating a clock, this is because London was the heart of clockmaking and it took time in other parts to catch up. It's not odd to have english clocks made for a different country, many have been made for countries such as China, India and France.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
