Breitling Die Set
I have never come across this make and I suspect most members on this forum are the same. Personally unless you are anticipating servicing a lot of Breitling watches then it is a big outlay. I purchased a similar tool for Rolex watches and it did not work and slipped under pressure. In my opinion it would be better to purchase a horotec case removing tool and just purchase the dies as and when you need them. I purchased this tool and have just added as and when needed. Some of the dies I have only used once.
591f3df361aa4_ScreenShot2017-05-19at19_46_28.png.fec1c2843764a80794808c4442fff5a4.png
Just recently got supplied with a simular if not identical breitling kit from my company, not sure how much it cost, i doubt it was that exepensive. I haven't had the chance to use them, however I have been told the kit is not sufficient to open all breitlings, some of the dies wont properly fit some models.
Edited by Ishima
Thanks for your replies
How does the Swiss style case opener compare with the Horotec?
Do the Horotec Breitling dies fit the Swiss style ?
Generally all dies are made for the Bergeon type. You can find the same Chinese tools for cheaper on aliexpress. They work pretty good.
I am not familiar with a Samsung but I presume you just attach pics via this which is at the bottom when creating a post.
Horotec is deffo good quality,Im near London and
HS Walsh has a counter in Biggin Hill so I will take a look before buying tools in future
I am no IT expert but some here are. Normally a triangle is showing that it is a unrecognised file or file format i.e. you should use jpeg images. Is the Samsung a mobile some here will know how to use.
This conversation is drifting into an area of chat so any conversation re PC, s etc should be in the "Chat section"
How do the Horotec and the Bergeon 5700 compare?
For one, the horotec in the picture above holds the case with the four plastic posts, but the bergeon require to remove the bracelet to hold in the lugs.
There is an entire thread dedicated to value case openers that you can read. My Chinese one works fine. They also copy horotec of many types.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
