Broaches
rogart63
Was thinking of getting some smoothing broaches for cleaning up the jewels in different movements with? But maybe it's not the proper tool for this?
Is there an other better tool that i can stick in a jewels and remove the old oil from the walls inside a jewel? Or am i overdoing? It's difficult to  get down into a little jewel and cleaning it with pegwood. And i have seen some smoothing broaches in small sizes on Ebay and cousinsuk.
Thought so to. But it's difficult to get the pegwood really sharp sometimes? So i was looking for something i could just put in the jewels and remove old oil or even pegwood that has been stuck inside? Found out with a little googling that bamboo sticks can be made sharper then pegwood. So i am going to see if i can find some of those.
Hands up.. I've used a smooth broach to remove a stubborn bit of crud from a jewel hole but it's not an acceptable practice and is very risky. The problem is the last thing you want to be doing, is attempting to ream the hole but more problematic is the jewel being very hard. So if the broach isn't maintained absolutely vertical during the process, the jewel is almost certainly going to chip.
The problem you may encounter with bamboo is its a harder substance on its outer skin than pegwood. So it may give the impression of having a finer edge after shaping but will be far less pliable than pegwood when attempting to clean the jewel hole.
Sent from my SM-T585 using Tapatalk
Bought some barbecue sticks at the store . the are sharp in one end. Can at least try and see how it works. No much money we talking a about
Proper pegwood isn't exactly expensive either.  Sharpening is a bit tedious, since it's easy to break or bend the tip in tiny jewel holes. But you get the hang of it after a while. I sharpen my pegwood with a Chinese junk-grade hobby knife, which works perfectly fine for the purpose.
http://www.ebay.com/itm/GJ01-Exacto-Knife-Kit-Set-For-Hobby-Scrapbooking-Crafts-Shop-CASE-RAZOR-NEW-/222517465560?hash=item33cf1311d8:g:-88AAOSwhQhY31jF
I don,t think cocktail sticks are good idea.They tend to break off at their tip which is a pain when inside a jewel. I recommend pegwood
I personally use those extra small cleaning swabs you can get from Cousins, that I first dip in some isopropyl alcohol, to clean out jewel holes.
These particular swabs aren't like the loose packed large general 'cotton buds' you see on supermarket shelves (and that would distribute fibres around the watch and absorb too much alcohol); their small tightly packed formation seems to work well and I'm a big fan for general cleaning too as they're soft enough not to scratch and strong enough not to break.
Anyone with any experience of using these as well as pegwood I'd be grateful for comparison comments on. I'm willing to change if pegwood is a more recognised and superior approach!
  • 2 years later...
As an update, Mark used a smoothing broach on the Seiko Navigator restoration. I have always wondered about this and it was nice to see that the burnishing or cleaning of the jewels made a difference in the functioning of the watch. His vial reveals a set of 12 but I can't see the maker of the set. This is something I'd like to know as Mark always seems to have an excellent taste in tooling.
Dean
I'm sure you are correct especially since Mark does use a lot of Bergeon products but that container of 12 broaches he used in the Navigator video didn't look like a bergeon container. I have become a fan of Mark's to the point that I like to use the same tools he does. Over time, as I switched and tried tools he used, I found them delightfully better than what I had been using.
Dean
Maybe Mark will comment.  I haven't seen the video, but I'm  guessing the use of a broach wasn't to burnish a jewel, unless it was something diamond charged as a typical hardened steel broach isn't as hard as the jewel material.
Edited by measuretwice
Actually you would never want to get in a jewel with a broach. The chances of cracking it are very high to almost certain. Pegwood only.
As for broaches I have a couple of sets of larger ones from Grobet that I got new (some years back) and are excellent. Also many old Bergeon sets, down to teeny tiny. Some colleagues bought new Bergeons cutting and smoothing a couple of years ago and the quality is fine.
I have some AF broaches which are perfectly good, certainly for a keen hobbyist level. As per nickelsilver above, I wouldn't recommend putting them near a jewel, you only need to tilt it slightly to damage a jewel hole.
As I was taught in my previous life as a mechanic, never use a material harder than the material you're cleaning, the same applies here just on a smaller scale.
    • Hi as an addition a pertaining to the assembly of a 6319B  which will be handy for those working on this caliber Polly's 6139 guide.pdf 6139A.pdf 6139B.pdf
    • Casio MDV106G-1AV Gold DURO200 I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable. Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them. Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀 The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
    • Hello Wai and welcome to the forum. A little information to enlighten you a little more TZIllustratedGlossary.pdf
