Dissolving broken screws
I have a couple of bridges that need screws removing and know of, but haven't yet tried, a warm alum solution. Are most/all bridges steel-free or are some alloyed in such a combination that there's a risk to the bridge itself? Additionally I saw a reference to the use of concentrated citric acid (often used for removing accumulated limescale in washing machines etc) for the same purpose. Has anyone tried citric acid?
Thanks
Roy
Never tried citric acid but I have dissolved several screws using alum, it works very quickly provided you keep the water warm.
Most bridges are plated brass but not all.  You can usually tell if a bridge is made of steel because it will be the same color as the steel components within the watch (pinions, ratchet wheel, screws, etc.).  Steel bridges are typically thinner than brass bridges and in my experience are usually found on the dial side (typically for the calendar works).
Thanks for the useful information.
"You can usually tell if a bridge is made of steel because it will be the same color as the steel components..."
That usually gives me pause for thought! I once used caustic soda to clean up an animal skull. It dissolved.
Roy
I need to remove a screw from an IWC Cal 83 main plate. I've inspected the plate and believe that the banking pins are also steel..... I was considering only submerging part of the plate into the alum, but am led to believe that this will case a "tide mark" on the plate.
Is there a way I can safely seal the banking pins (in shellac for example?) or am I best just living with a tide mark?
I've done it both ways without any issues.  Once I suspended the plate with a bit of copper wire so that only half of the plate was submerged in the alum bath in order to dissolve a screw without risking damage to a post which I was sure was steel.  The plate was silver plated brass and the alum bath didn't leave any marks on the plate.  In fact I've used the alum bath method on three occasions and it hasn't ever stained the plate.
Usually if there is a bit of steel on the plate which I don't want to be dissolved by the alum I'll cover the steel with silicone calk (like you would use to seal around a sink).  Since the calk is water proof, the alum solution will not be able to get at the steel underneath.  I usually apply the calk with an oiler under the stereo microscope.  It's important to make sure the steel bit is completely encased though because if it's not then the steel will be ruined by the alum bath.  The calk can be removed fairly easily with a bit of pegwood after the bathing is complete.
Have a seiko 6117 plate in the alum bath right now. Did it the hard way and removed all steel parts before i dipped it in alum. So before i can put the movement back together again i have to put the threads back on the movement plate. I removed the balance jewel so hope i could get it back in the right position again.
The threads for the trainwheel bridge are special inserts that are pressed into the movement plate.
Can take some pictures.
Have never seen any tide mark or something to the plates. But clean very good after as the crystal from the alum can still be there.
Edited by rogart63
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
