sekonda chronograph
5 hours ago, Johnnie said:
Hi Busakaz, What a good looking watch, I like it very much, has it got a name or model number?
It's just a sekonda 17 j but there is another name, poljot strela and the movement is 3017, it's the watch the Russians went to space with....
4 minutes ago, Johnnie said:
Hi, well as I said I like it, the reason I asked for name or model number is that I will keep an eye out for one!
Hi Johnnie, there are some on the bay type in poljot 3017 happy hunting.
1 hour ago, Johnnie said:
Yes a superb looking watch. I will indeed be keeping an eye out for one, it's seems they do a black dialed one but I prefer the lighter coloured dial. Enjoy your watch!
Cheers mate
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
