Tag Heuer wk111a-0
Hi,
I have a tag digital watch, and it is doing something very bizarre.
It is going backwards! The minute hand is literally going backwards.
I'm not sure if this is an easy fix or not, or if anyone else has come across this problem? When setting the time the hands only move one way, no matter what direction you move the crown.
Any advice and thoughts are much appreciated. f56fa22f39d9a09318b0cf222cd28e4b.jpg
Sent from my HTC One M9 using Tapatalk
Courtesy of Citizen...
"A quartz watch can run backward only if the stator (a component of the movement) is damaged in such way as to change its relationship to the rotor (step motor in the movement). If this has happened, the watch movement will generally need to be replaced."
