Greiner ACS900 in LA area
maclerche
If you live in LA or the area around, so there is a Greiner ACS900 on sale for only $2,700,-  I know very well that it is a great deal of money, but it is only 1/3 of what a new one costs (Cousins 10.300,- USD) and it seems to be entirely new ... I'm considering the even in spite of expensive shipping and customs ... but unfortunately, it must be 115V AC, it is not the voltage that can be found in LA and US in general?
http://zoheny.com/product/details?product=16755
Edited by maclerche
no URL
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
