Faceplate clamps
StuartBaker104
I recently landed an original faceplate for my boley and leinen lathe, but it doesn't have any clamps with it.
Been trying to work out a solution without spending too much, and the best I've come up with so far is to modify some of these http://www.faithfulltools.com/p/FAITMC114/Toolmakers-Clamps#_
...unless anyone has any better ideas or practical experience.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
