Need new motor for BTM watchmaker lathe
Tmuir
My BTM lathe is a war issue version and the motor that is currently driving the lathe is about the same vintage as the lathe, and worst of all is huge and ways over 10kg.
I've just sold my BSA WM20 motorcycle so have some funds to put into new tools and would like to replace the motor for my lathe.
I was thinking about buying a Sherline lathe motor and adapting that, but I'm open to other suggestions. I know I could buy an old sewing machine and use the motor from it, but then I'm back to having a motor that is probably atleast 40 years old. I do want one that has variable speed, the foot pedal would be a nice to have, but not a problem if it doesn't have one.
Anyone have a better suggestion than a Sherline lathe motor, and no I dont want to spend £1500 for the Bergeon lathe motor?
Once I've got a new motor I will make a new base for the lathe and refurbish the lathe too.
Thanks Tony
Edited by Tmuir
correct spelling mistakes
I would try with a sewing machine motor,it can be adjusted right out of the box and is easy to mount on a plate or worktable. .... and soit  is cheap, even from new! You might have to change the pulley!
An alternative is to find a small standard 230V motor and mount it on a plate. It is also possible to use a small 3phase motor and then add a capacitor. The method also makes it easy to reverse with a toggle switch. If you choose the method so I will elaborate and throw a wiring diagram up!
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
