Removing Balance
N00b question but I've seen two recommended methods to remove the balance assembly from the movement, and now I'm confused which is the best / more correct ?
1. is to lift the balance cock and very gently remove it by just holding the cock and making sure as to not snag the balance wheel. so that the wheel hangs on the hair spring, as per Mark's videos. Also when using this method how does one go about flipping it over to lay it in the parts tray, other than very carefully ..
2. is to pick it up by holding the balance cock and wheel together in your tweezers, as per the picture attached (sorry for the blurry mobile phone pic).
So which is the most correct way and more importantly why? Which way should a n00b like myself be using.
I use the second method. As i am elderly i tend to shake a little making the first method difficult.  But that can be risky and i think u can bend the pivot if you hold to tight? On balances that has a jewel that you can remove . I do that and put it back after i have put the balance back on the movement?
I use both methods. I've once tangled a hairspring using method one (balance suddenly sprung upwards due to sticky lower jewel). I've once bent a lower balance pivot using method 2 since the lower pivot was stuck again, and the balance always lifts at an angle when you use this method.
I usually go for method 1, and use method 2 if the balance is sticky. If it is too sticky, then I pick up an oiler in my other hand and use it to persuade the balance wheel to lift.
2 minutes ago, madchops67 said:
I use the first method to avoid damage to the hairspring, just in case it's gets nicked by being compressed against the balance wheel and balance cock.
That can't happen, because the shape of the upper pivot into the balance cock hole the makes so that there is always a certain space between the wheel and balance body.
On the other hand, when you keep the wheel dangling by the hairspring, the latter can get distorted by catching int something, or by the wheel weight itself.
It happened to me once before, maybe because I gripped to hard with the tweezers and the outer part of the spring end up distorted. It may have been pinched or rubbed against the balance cock. That is jus my experience, so that's why I use the first method.
I prefer option 1 but use option 2 if the whim takes me.
I like to lift the cocktail and rotate so it sits on the movement leaving the upper staff pivot loose. Then lift the lower pivot out its jewel. Then lift the assembly. That way you'll not end up with a jumbled mess if sticking pivots in the jewel hole.
On old pocket watches there is a third option.
3. Loosen the stud retaining screw. Push the stud down away from the balance cock. Remove the balance cock. Then remove balance wheel and staff. It can then be reassembled on the worktop.
I'd have to say it depends a bit on the movement.  In some movements the center wheel is very large and will cover a good portion of the balance making option 2 difficult.  Other times, if the movement hasn't been serviced in quite a while or you know the balance pivots may stick, option 1 goes out the door.
I generally use the first option but with a caveat; Once the balance cock is loosed I'll lift it and shift it slightly to release the top pivot from the jewel, then lift the balance wheel up out of the bottom pivot before removing the entire assembly.
If you use method one you don't need to leave the hairspring dangling. I use a balance stand and a bit of rodico and it could sit on its standard for years if necessary. Have attached some pictures for demo. Just remember when taking the balance assembly of the stand to hold the wheel gently incase lower pivot sticks in the rodico. Then release from the rodico.
I think people prefer method 2 to avoid having to flip the wheel over when working on the balance.e1e993a4a39694fe7cc590f463b3bcd3.jpg3082f14a7ea479edbf4eec8d2c605dac.jpgc13f1cabc442e023536908a694af60d7.jpg
Great question ... and answers!
I've always gone for option 2 as it has served me well but I might start using option 1 for some of the reasons given.
And digginstony I am so getting (or making) myself a balance stand! :)
Edited by WatchMaker
I use this method so I can sneak up on it, save for the third method there that I haven't thought of, pretty slick!
BTW I just got one of those balance stands/tacks and it's extremely useful.
What has that to do with this? [emoji4] Better to let it swing?
Yep it's more of a swing than a vertical lift, to move the balance bridge from its fixing stud or studs Then ease the lower pivot from its jewel but it still necessitates a slight lifting motion ??
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
    • The two measurements of particular importance wound be the height and the strength,  the length would obviously correspond with the increase/reduction of half mm of barrel diameter. There is a big difference in price considering that the more expensive one is the shortest. The longer one might be ok ? But then it is taking up more room in the barrel, might it effect the unwinding ? I wouldn't have thought so for just that small amount.  Ideally a pro might reduce the longer one to suit. But there is some information that might help, do you have the one that was fitted to measure up, though not necessarily the right one.
