Avia quartz, battery terminal.
Len33
Hello, everyone!
I have an old 'Avia'  quartz watch and the lower battery terminal has come off.
It seems that it was origionally spot welded into place.
Any suggestions as to how it can be successfully re attached?
Soldering does not seem like a good idea, though the concept does suggest a good way to go.
Conductive adhesive? Mmmm! Not so sure about that, especially with the constant downward pressure applied by the battery.
Then again, this is the 21st century..............so!
Anyway, all suggestions are very welcome and I feel sure that the answer is out there somewhere.
Thanks.
certainly possible to solder it.
See my repair on an ETA 955 here:
You have the advantage of having the missing part, I didn't. And it looks like it is a more accessible place to join. It really now depends on 1: have you got a really small soldering tip and 2: is the movement rare or expensive. Just in case it goes wrong? I was not too bothered as the 955 seems to be readily available.
But to also add, that I have since tried another similar repair on a different movement, again without the part and with even more difficult access and that repair did not work.
Agree with the solder option. I would use a low temperature flux cored solder. Clean both surfaces with a fine abrasive and tin them. Then bring the two surfaces together and heat to make the joint.
I'm wearing an Avia just now. A nice neat watch with no pretensions.
Neil
That is a ETA 944.111 movement? Not sure but i don't think they are that common this days? If you don't succeed i think i have a couple of NOS circuit boards that was left over from a project that didn't went that well. Movement was to rusty.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
