Finger Cots
chadders1966
Hi
Just wondering if anyone here has ever bought the A*F finger cots from Cousins? I've tried various other cheap ones before, but they are usually too tight. The A*F ones come in S,M,L & XL, but it doesn't say what these sizes equate to. I'm interested in getting some, so if anybody can advise on the size of these it would be helpful. Thanks
Stephen
I bought  medium and they work  for my long fairly thin fingers . Size 10-10,5 in normal gloves. But sometimes a large could work better at least for my thumb. The latex finger cots are stretchier then most other cots i tried?
I stick with medium next time as it is a little work to have to sizes around. Usually only have a finger cots on my index finger when i work on the movement .
Thanks for the responses, much appreciated. Interesting that you say they are stretchier than others, could be what I need. What is the diameter on the medium ones, before putting on and stretching? The ones I have at the moment are about 2cm and I find them too tight, particularly on the thumbs.
Stephen
Rather than throw them out Stephen, use them and cut the thick rubber ring with a pair of scissors when fitted.  This greatly reduces the pressure and will at least allow you to use them.  This is exactly what Inam doing just now to work my way though some tight ones.
