Finger Cots
chadders1966
Hi
Just wondering if anyone here has ever bought the A*F finger cots from Cousins? I've tried various other cheap ones before, but they are usually too tight. The A*F ones come in S,M,L & XL, but it doesn't say what these sizes equate to. I'm interested in getting some, so if anybody can advise on the size of these it would be helpful. Thanks
Stephen
I bought  medium and they work  for my long fairly thin fingers . Size 10-10,5 in normal gloves. But sometimes a large could work better at least for my thumb. The latex finger cots are stretchier then most other cots i tried?
I stick with medium next time as it is a little work to have to sizes around. Usually only have a finger cots on my index finger when i work on the movement .
Thanks for the responses, much appreciated. Interesting that you say they are stretchier than others, could be what I need. What is the diameter on the medium ones, before putting on and stretching? The ones I have at the moment are about 2cm and I find them too tight, particularly on the thumbs.
Stephen
Rather than throw them out Stephen, use them and cut the thick rubber ring with a pair of scissors when fitted.  This greatly reduces the pressure and will at least allow you to use them.  This is exactly what Inam doing just now to work my way though some tight ones.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
