Vintage Citizen 'Bling'
anilv
Hi guys,
Thought I'd share pics of an old Citizen automatic which I got recently.
Its an automatic with the cal. 6501, the serial number starts with 411xxx so its from Nov 1974. Citizen's dating system is slightly different from Seiko's in that the 2nd and 3rd digit denote the month of production, here 11 = November. For Seikos, while the year is indicate by the first digit, only the second digit reflects the month, 0=October, N=November and D=December. You still need to estimate which decade though.
Crown is an original Citizen which is nice and the bracelet is the correct one for the lug width and the bracelet matches the case-shape.
It has a Rado feel, the dial reminds me of some of the stone dials in the diastar range.
The case is an aluminum one and usually doesn't wear well as it seems to react badly with sweat. There is a black coating which has worn thru in places , the back in particular is pretty worn. I thought of getting it painted on the edges and top where it shows. I won't paint the lower surface as I don't want any paint getting thru my skin, besides, it'll only wear off again.
The bezel seems to be stainless steel, I'll be polishing that first, if it comes up ok then I'll paint it. No point painting it if the bezel is all scratched up!
Citizen went through a phase where they used a lot of aluminum cases. I have a few but they usually don't last well.
Have a good Easter weekend!
Anilv
Thank you for sharing -I like the dial very much!
This week I also received my first  "blink" vintage from the Seventies which fits very well to your Citizen :-) - therefore I will add it here.  It's a Tissot PR-518. Almost in perfect conditions. Unfortunately the crown is not the original crown. It was replaced by a Tissot crown but the replacement crown does not allow to quick change the day by pressing.
What is somehow funny - the day changes twice within 24 hours. Therefore every day is double. You can see it here: Tissot 2571
I haven't checked yet if there is really Tissot inside - you never know what you get from auctions but it runs very accurate.
Hi Lantalon,
NiceTissot, I've have a few where the day changed twice, probably a design shortcut!
Anyway that's one good sign that the machinery is original as not many movements have that 'feature'!
I like the bracelet as it matches the watch very well...probably original?
Thanks for sharing!
Thank you for this information! That's good to know. The bracelet seems to be original - it's very solid. A few links are probably missing, but I still have to remove one link for my wrist.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
