Elgin Unitas 6498 Balance Spring.
I'm having a problem with the balance spring stud that seems to be stuck on the regulator arm. The lock screw is missing and the stud seems to be different from other ones I've seen. Has anyone ever come across a similar problem or know if the stud is the right one? I hope It wasn't set in with loctite, and I know this is a delicate situation... any advice is truly appreciated.4825b66a749bffb5b3058a93153101c5.jpg8dadb904a7d112df6c381945c21f9712.jpg4ff2b1c8f540a362c85fbe553175c0d4.jpg5177f02c426f33de56d91fa65514a93b.jpg
I don't think that is your biggest problem (though it is a problem). Your regulator is broken - you only have the "boot" - there should be a pin at it's right (in pictures).
Matabog, thanks... I kinda figured that something was missing from there and I've never seen these older 6498 movements.
I have had this problem & I pushed it out with my staking tool. You have to use a stump that is open both ends so the hairspring is not damaged.
Clockboy, I'm going to attempt that tonight and hope that I can successfully remove the pin without damaging the hairspring, although the hairspring is already deformed and looks bad. I'll probably want to replace it if I can't manipulate it back to a decent shape...so this will be good practice for me.
Take your time making sure you do not damage the hairspring or bend the arm. If I remember correctly the one I moved was with a firm push.
I tried last night to attempt to remove with a firm push as well but to no avail. I'm thinking it may have loctite considering there isn't a lock screw to hold the stud. Hopefully I can get it out with a staking tool like you mentioned, and I'll try to be careful not to damage the hairspring or damage the arm.
Can't you stake this out? Use a stake and a bench block
Success!!! Got the hairspring manipulated back to a decent shape and seems to be running smoothly than before. Thanks guys for all your input. Clockboy, I was extra careful not to damage the hairspring for it takes patience and a great of steady hands that I don't have...yet. [emoji1360] 937f122adfdfb16127e3e60c212ed403.jpg
This may sound a bit daft but I'm beginning to conclude that the stud clamping screw is so much missing as intentionally omitted.
I currently have a 17J UT6497 in a Le Cheminant pocket watch and a 17J UT6498 in a Summit pocket watch, both from the late 70's/early 80's, and both without stud clamping screws. I was going to try and fit a screw to the 6497 as believed it to be missing, but recently acquiring the 6498 with the same omission suggested that it was intentional. Now this post convinces me even more.
It begs the question "why?", although the stud does seem to be quite secure in both cases. Thankfully neither watch is in need of any H/S adjustment else it would be more of an issue.
Marc.  Maybe the "screw" hole stops just short of breaking through into the stud hole to allow a small punch to be used to dimple the stud hole slightly.  This would allow the stud to be gripped in the hole and also allow further tightening of the stud in the hole later on if required.   Just a thought!
Could You replace the missing regulator pin?
The end curve seems still distorted from here [emoji4]
The hairspring would definitely need a replacement, although I didn't have to fuss with the removal I was able to form the spring somewhat back to a decent shape to get the movement going. Next phase would be replace the spring and strip down into the ultrasonic cleaner.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
