Elgin Unitas 6498 Balance Spring.
I'm having a problem with the balance spring stud that seems to be stuck on the regulator arm. The lock screw is missing and the stud seems to be different from other ones I've seen. Has anyone ever come across a similar problem or know if the stud is the right one? I hope It wasn't set in with loctite, and I know this is a delicate situation... any advice is truly appreciated.4825b66a749bffb5b3058a93153101c5.jpg8dadb904a7d112df6c381945c21f9712.jpg4ff2b1c8f540a362c85fbe553175c0d4.jpg5177f02c426f33de56d91fa65514a93b.jpg
I don't think that is your biggest problem (though it is a problem). Your regulator is broken - you only have the "boot" - there should be a pin at it's right (in pictures).
Matabog, thanks... I kinda figured that something was missing from there and I've never seen these older 6498 movements.
I have had this problem & I pushed it out with my staking tool. You have to use a stump that is open both ends so the hairspring is not damaged.
Clockboy, I'm going to attempt that tonight and hope that I can successfully remove the pin without damaging the hairspring, although the hairspring is already deformed and looks bad. I'll probably want to replace it if I can't manipulate it back to a decent shape...so this will be good practice for me.
Take your time making sure you do not damage the hairspring or bend the arm. If I remember correctly the one I moved was with a firm push.
I tried last night to attempt to remove with a firm push as well but to no avail. I'm thinking it may have loctite considering there isn't a lock screw to hold the stud. Hopefully I can get it out with a staking tool like you mentioned, and I'll try to be careful not to damage the hairspring or damage the arm.
Can't you stake this out? Use a stake and a bench block
Success!!! Got the hairspring manipulated back to a decent shape and seems to be running smoothly than before. Thanks guys for all your input. Clockboy, I was extra careful not to damage the hairspring for it takes patience and a great of steady hands that I don't have...yet. [emoji1360] 937f122adfdfb16127e3e60c212ed403.jpg
This may sound a bit daft but I'm beginning to conclude that the stud clamping screw is so much missing as intentionally omitted.
I currently have a 17J UT6497 in a Le Cheminant pocket watch and a 17J UT6498 in a Summit pocket watch, both from the late 70's/early 80's, and both without stud clamping screws. I was going to try and fit a screw to the 6497 as believed it to be missing, but recently acquiring the 6498 with the same omission suggested that it was intentional. Now this post convinces me even more.
It begs the question "why?", although the stud does seem to be quite secure in both cases. Thankfully neither watch is in need of any H/S adjustment else it would be more of an issue.
Marc.  Maybe the "screw" hole stops just short of breaking through into the stud hole to allow a small punch to be used to dimple the stud hole slightly.  This would allow the stud to be gripped in the hole and also allow further tightening of the stud in the hole later on if required.   Just a thought!
Could You replace the missing regulator pin?
The end curve seems still distorted from here [emoji4]
The hairspring would definitely need a replacement, although I didn't have to fuss with the removal I was able to form the spring somewhat back to a decent shape to get the movement going. Next phase would be replace the spring and strip down into the ultrasonic cleaner.
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
