Today’s Competition 2
oldhippy
My thoughts on the clocks are,
1 American Pillar and Scroll clock
2, American Ogee clock
3 English 19th century double fusee libary clock, looking at the movement I would describe it as a platform lever, it has a pull repeat and soft or loud switch on the side and the case is probably a five glass. a very fine clock if my house had a library I would want this.
4 French Empire style Portico clock
5 French Ormolu Figural clock
6 This is a Balloon clock not sure wether this is English or French but this one will have a 8 day platform movement
1st Not sure but I think it is American
2nd American 30hour wall clock most likely a Ansonia movement
3rd Fusee striking mantel clock with a platform escapement
4th Portico piler mantel/bracket clock possibly French
5th A good quality French mantel clock. A gilded bronze case
6th Inlaid ballon style clock
Well 137 views and only a few responded. :angry: Because wis1971 had another think about the English Carriage Clock you again got them all correct. clockboy a close second.
Thanks folks. I will have to think of something different next time.
I wanted to play but had no idea... Anyhow, my guesses were as follow:
1- wall clock with a painting
2- wall clock with a glass window
3- mantle clock with a handle
4- fusee clock with no case
5- greek column style clock :)
6- fancy golden clock with some person sitting on it
7- funny looking mantle clock
