First watchfair
transporter
Well I managed to get to a watch fair, pretty happy, no really happy with the day, some damn expensive stuff but that's to be expected. But happily loads of second hand tools etc to browse and buy, which I did, tweezers, mainspring winder, Arkansas stones, poising calipers, new oilers to name a few, traders really helpful and chatty with loads of information, so if anyone is a member of the southwest BHI I thank you for a well run day with me a mere hobbyist walking away extremely happy with a bag full of tools that would of broke the bank if I'd bought them new.
mind you I've just had to spend £53 on some L&R ultra fine solution from cousins, but with the savings at the watchfair I can swallow it haha.
  • 4 weeks later...
Was the watch fair in London at the Brunel University ?
Sent from my SM-N910F using Tapatalk
The London one is ok but full of collectors,and lots of vintage stuff with big big price tags but managed to pick up a Pulsar pepsi diver for £20 great condition when home realised it just needed caseback gasket dressed it with a WatchGecko rubber strap, Very happy
Nice one, yep there was a few collectors at this one but prices weren't too bad, even went back after going to bristol to see if I could snaffle an ultra sonic cleaning machine that I had seen, everyone was packed up but managed to find the owner, I walked off after he asked £250 for it, to be fair it was a good one but used and untested.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
