Greetings from metro Detroit
SPC
I work as an engineer in the automotive industry, but have had a fascination with watches since I literally can remember.
My first watch was (and is) a 1968 Timex Electric Calendar 91242 given to me as a gift for my first Holy Communion back in May of '68 from my Godmother.
It's the want of this watch to work again that led me to working on watches a few decades later.
The collection mainly consists of Bulovas from the '40's-'50's and Timex's from '50's-'80's (this includes two models from the inaugural year 1949... a Monroe and a Coronet).  You can also throw in a couple of '50's Longines as well.
I am currently working on a 1953 Bulova American Girl "Y" (for my daughter) as well as a '51 Timex Marquette.
I am grateful to Mr. Lovick having posted videos that have been a wealth of information (including proper oiling techniques, and identifying which oils/greased to obtain and where/when to use).  I had queried and searched for that info for quite a time, finally finding it in his repair videos.
I look forward to participating on this site!
Welcome SPC! As a former autoworker living around the D, I can tell you this is the best place for info and opinions on all sorts of watches. We do like pics, so if you get a chance share your collection and what you are working on. Mark has done a great job in his vids, simplifying service and repairs for those of us with less experience. Look forward to seeing your posts and don't be afraid to ask questions!
Dave
Nice! Another Timex collector, and you have a couple of the grails, too. I don't think I've ever seen a '49 Timex, although I've seen ads for them. In case it's helpful, I'm currently fostering the document collection from the old Timex forum here -
Timex Documents
Have fun!
Edited by dadistic
update
Hello SPC and welcome from me,
I noticed your reference to the Timex and personally I have an interest in the Bulova Accutrons which I have always found to be lovely bits of advanced engineering for their time.  This is a great forum and loads of help and good advice is always given if needed.
Cheers,
Vic
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
