Changing BPH from 21600 to 18000
I have a Ronda 1217-21 with a damaged balance. I have a spare 1213 movement with a good balance, but it is a 18000 mph movement. The 1217-21 is 21600.
Is the escape wheel the only other part I need to change to complete the change to 18000.
Presuming it's the same movement just a different train count and the parts will fit I would think all of the train wheel will need changing and possibly the barrel, this can easily be checked by counting the teeth on all of the wheels and pinions to see if they are the same number. The pallet may need changing as well.
it is possible to time a watch up perfectly on a timing machine with a wrong traincount wheel in and the watch will gain or loose time even though the timing machine shows perfect in all positions.
That's the problem I've been chasing. The timegrapher says it's running fast, but it loses about 10 minutes an hour. I finally realised that the balance is from a faster beat movement. Most of the parts are interchangable, apart from the balance and escape wheel.
please count the teeth on the escape wheels,I think they have both 15, in which case, it makes no sense to change them.
If you change the escape wheel, though, change the pallets, too - the escape wheel and pallets usually are paired (IMHO small adjustements are made for each pair)
Edited by matabog
If you have a wheel with the wrong amount of teeth/pinions fitted (wheel from different bph) then even if you time it perfect in all positions the watch will gain or loose.
When you time up a watch say at 18000bph the microphone is listening to the escapement and in theory will oscillate at 18000 times an hour.
If you have a wrong wheel fitted the ratio of the other wheels are turning at the wrong rate meaning the wheels/hands aren't turning at the correct speed, although the timing machine says it's timed up it is only actually confirming the escapement is running bang on at 18000bph because that's all the timing machine can listen too.
If you count the teeth on all of the wheels and pinion there is a fotmula to work out the beats per hour, if your answer is not 18000 or 21600 then you have a wrong wheel fitted, it's just a matter of working out which one.
Hope your good at maths
OK. The only difference was in the fourth wheel, as suggested above. Around 60 teeth on the 18000, and 76 on the 21600.
All other wheels and pinions were the same. I'm a bit confused as to why the pinions on the escape wheels were the same on both, as they have to mesh with the fourth wheel. Also, Borel list them as incompatible. Maybe someone had been doing a bit of swapping sometime in the past.
It certainly runs much better now, just need to check if it runs to time as well.
    • Hi. Sounds like a problem clock, can you post some picture# of the clock and the parts in question please.       Thank you
    • The first broke while i was using a dremel to shape the jumper spring at the join, i guess you call it the fixator, the disk grapped hold and flicked it off . The second time same place but while i was filing.  This steel feels more malleable, it is annealed steel. Working out the detent on the jumper is a real. pain in the butt.
    • I'm trying to get a balance spring Mantel clock to run to time - even with the regulator set to Slow it's gaining 40mins a day (the balance spring was damaged on receipt so it may be shorter than it should be - can't think why else it should run fast, especially as it is quite dirty & apparently hasn't been working for some time.). Anyway, looking closely at the train I've noticed the pre-escapement wheel is slightly 'dished'. Could this have been done by a previous tinkerer to get around a problem that should have been addressed by e.g. bushing pivot holes?
    • Hi Rich, now i realise that you spring broke. how did it broke, may be when grinding the fixator part with the dremel? If so, then guess You have let it to vibrate free, this is wrong. One must keep the spring pressed with finger to boost the vibrations, other vice it resonates and breaks.
    • The movement is so called 'Tongji', standard chinese movement. The stem can still be used with the help of extender.
