Hello from Oldwamkr
i got a job,when 18,in a jewelry store in my home town. the owner,turned out to be a cmw and cmc. he agreed to take me on as appretice. after spending time as a clerk, sweeping up under the lathe benchs, hand filing and theroy, disassembly, cleaning, polishing,assembly, i had spent two yrs. found  an appreticeship program (for 5 yrs) sponsed by NCWA license board.I did my (ojt) in the NC mts. the  owner of the store, she was 5 generation CW, her dad CMW,CMC,her mother CMW, husband CCM,both her son and daughter worked there. I lived with the family,in their home,(24 hrs.per day.I got a job at the old waltham factory.building the A-13A,8 day aircraft clock,for the goverment. I did final assembly,final timing(30 sec in 8 days) !!! a lot of balances to poise. by the way it was done with hand  calipers, you vibrate the calipers with tweezers, the heavy point allways falls down. the last watmkrs guild was in waltham MA, I loved it all,a master was so much more than a profesional,at least to me.I still love fine mechinal works. thank yall,for letting me participate in your group  oldwamkr
That is a great bit of historical storytelling. Thank you for sharing it.
J
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
