Jewel Cap Springs
Hi
I'm working on a small lady's watch that has some jewel cap springs I've not seen before in my whole 18 months of watchmaking.
Anyway, one is shaped like a 4 leafed clover and the other has a lyre shape. I think the clover shaped one is like a Novodiac spring and the lyre shaped on is hinged - sort of like an Incablock spring.
Any suggestions are welcome.
It was my mother's Bulova and it's NEVER been cleaned. Just getting the hair out of it made it go...
Dave
PS - I'd post a photo but, sadly, I don't know how.
1 hour ago, Folkvisor said:
Hi
Dave
What's the caliber?
J
@rogart63 is correct. DO NOT try doing without the tool. YOu might be able to get it off by nudging with tweezers, but you'll never get it on afterward and 99.99% chance it will fly into the Nth dimension. You can use these little tools:
I also probably have spare parts for that movement...have to look.
J
8 hours ago, clockboy said:
They are KIf size 2-2. I recommend you use a Kif shock tool or make one out of peg wood. I have removed with tweezers & peg wood but they can be real tricky without the correct tool. I have added a Bulova pdf showing the shock springs required.
KIF_Bulova.pdf
Just now, matabog said:
Just use two tweezers and rotate. Careful not to push too hard and brake it.
Thank you both for the information. I'm thinking I'll just leave the KIF DUOFIX spring alone for now.
Just as an aside, My grandfather was from Biled. At the time it was part of the Austrian-Hungarian empire.
It is possible to remove and fit these Kif springs with a piece of peg wood and a pair of number 5 tweezers but they are very fiddly and as already said you will probably ping a few into space before you succeed, you used to be able to buy the springs in tubes of 10 and they weren't much money if you did want to try, they are like a bayonet fitting.
  • 5 months later...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
