Jewel Cap Springs
Hi
I'm working on a small lady's watch that has some jewel cap springs I've not seen before in my whole 18 months of watchmaking.
Anyway, one is shaped like a 4 leafed clover and the other has a lyre shape. I think the clover shaped one is like a Novodiac spring and the lyre shaped on is hinged - sort of like an Incablock spring.
Any suggestions are welcome.
It was my mother's Bulova and it's NEVER been cleaned. Just getting the hair out of it made it go...
Dave
PS - I'd post a photo but, sadly, I don't know how.
1 hour ago, Folkvisor said:
Hi
Dave
What's the caliber?
J
@rogart63 is correct. DO NOT try doing without the tool. YOu might be able to get it off by nudging with tweezers, but you'll never get it on afterward and 99.99% chance it will fly into the Nth dimension. You can use these little tools:
I also probably have spare parts for that movement...have to look.
J
8 hours ago, clockboy said:
They are KIf size 2-2. I recommend you use a Kif shock tool or make one out of peg wood. I have removed with tweezers & peg wood but they can be real tricky without the correct tool. I have added a Bulova pdf showing the shock springs required.
KIF_Bulova.pdf
Just now, matabog said:
Just use two tweezers and rotate. Careful not to push too hard and brake it.
Thank you both for the information. I'm thinking I'll just leave the KIF DUOFIX spring alone for now.
Just as an aside, My grandfather was from Biled. At the time it was part of the Austrian-Hungarian empire.
It is possible to remove and fit these Kif springs with a piece of peg wood and a pair of number 5 tweezers but they are very fiddly and as already said you will probably ping a few into space before you succeed, you used to be able to buy the springs in tubes of 10 and they weren't much money if you did want to try, they are like a bayonet fitting.
  • 5 months later...
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
