Seiko Watch Parts Needed
Hi
Working on a Seiko 7s26c ...I need
A - (1) Date dial Guard screw Part # 0012 354
B - (1) Day Date corrector Wheel Part # 0737 300
Does anyone know the best place to purchase these parts in the USA.
I have searched part numbers on a few sites Esslinger and Ottofrie but no dice.
Regards
Anthony
Mate jump on ebay and search for "thewatchcollector" Ramon is a source of many seiko parts mostly used, he usually sells batches of old movements for very little, I grant you they are dirty and some will never run again but they are a cheap way of getting alot of parts, and he's based in US but the items come from the phillipines, but he is very trusted throughout the seiko community, myself included.
5 hours ago, adiorio110 said:
Hi
Regards
Anthony
Think i could have those? Send me a PM . I  can take a look?
Didn't read that your are in USA . That will complicate things a bit :)
Edited by rogart63
Rogart
I found the screw and  I located the part I needed part #  0737 183 ..The other number was for the B version. Its only 4 bucks it would be more to ship it from Sweden . But thanks for the offer .
Anthony
4 hours ago, dman2112 said:
Anthony. I should have day date corrector. I have b and c parts and I would just have to check to make sure it's a C part if applicable. Do you still need?
Yes I can still use the c version.. Let me know
Thanks
Anthony
Anthony,
OK, yes I have the "C" version of the plastic corrector wheel.  I am in NJ and I think you are in NY?  You may have it for FREE.  I think if I tape it between two business cards and put it in a standard envelope it should be OK with just a forever stamp.  If you want me to put it in a bubble envelope just go to USPS.com and send me a prepaid first class postage from 07930 to [email protected]
ALTERNATIVELY you can have the whole movement for $25 plus postage.  This was a brand new movement.  It is missing three parts, the day wheel, the hour wheel, and the clip for the day wheel, otherwise perfect.  PM or email me what you want to do.
9 hours ago, dman2112 said:
Anthony,
dman2112
I'll pm you
Thank you
Regards
Anthony
1 hour ago, dman2112 said:
Anthony. On its way. You should get it tomorrow or Sat
You the Man... Thanks .. I ripped down and rebuilt the watch 3 times.. Of course I could not completely check my work without that part. I am excited to see how I did. Hardest part was getting the roller jewel in place.. But I am getting better(quicker) at it ... Have you been doing this long?
Any suggestions as to what I should try next?
I'm thinking about perhaps buying a broken day date watch and trying to trouble shoot and repair it.
Regards
Anthony
Thanks again... dman2112.. I already received the part and installed it ... Everything works fine ...I already ripped down and rebuilt this watch 3 times ...Now I have to tear it down, clean and oil properly  before rebuilding it again. That should go pretty fast.
Already looking for the next level build.
Regards
Anthony
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
