ETA 2451
Hi
Assembling an ETA 2451, for the first time when attaching the cannon pinion I broke the centre wheel jewel. I was using a holder with centre support, but I broke it anyway - I think I may have used too much pressure. I have a number of questions, please feel free to answer any or all of them :)
1. Does anybody know the size of this jewel, or have one they can measure? Alternatively I do have an ETA 2571, will this be the same size?
2. Apart from Cousins, where is a good place to order these jewels? I don't want to pay the £50 or so they charge.
3. How much pressure is needed to attach the cannon pinion? I am used to firm pressure, but this one seemed to need a lot.
4. What is the best/most secure method to attach the cannon pinion? I have just been using tweezers. I did read somewhere that it was safer to hold the cannon pinion in a pin vice and push on - anybody do this?
Any advice appreciated. Thanks
Stephen
If there is no centre seconds then I would just sit it on and push down with the back of my tweezers, make sure you oil/grease it first and  put the minute wheel on after then you won't damage any teeth.
One firm push should do it, are you sure it's not too slack and you are trying to push it on too far?
Edited by Tiktok
Isn't the 2451 like a 2824-2 ? It's a driving wheel with a cannon pinion in?
If so there should be no problem? The cannon pinion with driving wheel should come as one unit? And would just drop into place? No force should be needed?
That is what the parts list says, but not what I have which is cannon pinion only.
Are you sure the pinion part hasn't just come away from the wheel and it should look like the part in the photo?
No, there is no driving wheel. Someone in the past must have replaced it with the wrong part - no wonder I had such trouble fitting it as it shouldn't be there! I will need to find the correct part. I am still faced with the problem of replacing the jewel though.
Sent you a message,
some pictures would be good, just had a look on google and it does look a very close family member to a 2824, I wonder if any wheels or parts would interchange with it. How many beats per hour is the 2451 calibre?
29 minutes ago, Tiktok said:
Sent you a message,
Don't think the parts from the 2824-2 would work in a 2451?  The wheel doesn't look the same? Found this on  Ebay http://www.ebay.com/itm/Lot-of-3-ETA-cal-2451-2452-2453-watch-movements-for-parts-or-repair-/361869659633?hash=item54411ccdf1:g:f7kAAOSwjDZYa6lo
Maybe that would be a good deal? instead of replacing the jewels? There is even an driving wheel with cannon pinion on one of them.
I was thinking more of the jewel possibly being the same size, I have an old bridge off a 2824 here I could send him if the jewel is the same size.
There are 5 different heights for the cannon pinion. Jules Borel lists the "where used" if you click on the appropriate part.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=ETA_2451
I've no idea why parts lists don't show jewels... you just have to measure up and buy standard parts. If you need them individually Then obsoletewatchandclockparts is often cheaper.
10 minutes ago, chadders1966 said:
Yes, I saw those. I think they would be a good deal for spares if I could press the jewels out. My movement is gold/copper coloured so I couldn't use the bridges directly.
The 2451 is an 18000 I think.
If it's 18000 then the wheels defenatly won't fit from a 2824. Is there any way you could measure the pivot that goes into the cracked jewel and that's one measurement we could compare with jewel size.
I have posted the bridge off the 2452 and a 2824 with the hope you might be able to rob a jewel out of one of them that will fit.
I have also put the friction wheel in from the 2452, it doesn't say it's comparable on that PDF sheet and might be a different train count but worth a compare whilst I was sending other bits, if it fits but it's a different height I have put the centre wheel and hour wheel in to match so you might get away with just altering the height of the hands if not too far off, but again check to see if wheels are the same.
Just post back what you don't use when you are ready, no rush.
    • See, what has happen is a normal consequece of the reducing the hammer size and changing it's shape by the removing metal from it. But here the hammer is adjustable and just adjustment is needed to correct, and this is what You have done. There is a rule for the adjustment and it is that the hammer must lay firmly on the seconds counter heart and there should be a litle free play in the same time of the minutes counter heart/hammer which alows counter movement of about 0.5 min on the small dial hand (+/- 0.25). Of course, there is no way to make one hammer to delay from the other, as they are one single part. What has changed too is the slope of the hammer head and thus the orientation of the heart has changed, and thus the switching finger position. This led to need of the finger position correction. The rule here is that switching of the minute counter has to start when the seconds counter hand is on '59'. Of course, the seconds hand must be positioned as so the resetting is at '0' exactly. If switching is earlier than 59, there will be no problem, but it will be wrong as reading can be not correct. If the switching starts later, the problems that You described can happen.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
