St. Patricks feast
15 hours ago, Folkvisor said:
I just had beer and french fries in honour of my Irish grandmother.
When I was a kid and wouldn't fall asleep my grandmother used to tell me that the Banshee would come for me if I didn't go to sleep. For some odd reason that didn't work...
Banshee.....good one! First time I heard of them was "Darby O'Gill and the little people" starring Sean Connery. (before Bond).
11 hours ago, Mark said:
I had Fuhk soup.
Not exactly Irish but I'm only 1/8th Irish and hate Guinness.
The Fuhk soup was delicious.
I ain't even close to being Irish, (German&Russian) just thought we'd celebrate more traditionally. Guinness isn't my first choice of beer either! What is in Fuhk soup? I mean, I see the tatties, but what else is in this?
Not tatties. It's Fuhk.
Fuhk is a type of pumpkin. Very delicious.
Looks like a good fuhkn pot of soup to me Mark! [emoji185]
Lol. It was.
Just picked them from a tree - I asked what they were and they said Fuhk - i said wash your mouth out!!! ....
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
