St. Patricks feast
15 hours ago, Folkvisor said:
I just had beer and french fries in honour of my Irish grandmother.
When I was a kid and wouldn't fall asleep my grandmother used to tell me that the Banshee would come for me if I didn't go to sleep. For some odd reason that didn't work...
Banshee.....good one! First time I heard of them was "Darby O'Gill and the little people" starring Sean Connery. (before Bond).
11 hours ago, Mark said:
I had Fuhk soup.
Not exactly Irish but I'm only 1/8th Irish and hate Guinness.
The Fuhk soup was delicious.
I ain't even close to being Irish, (German&Russian) just thought we'd celebrate more traditionally. Guinness isn't my first choice of beer either! What is in Fuhk soup? I mean, I see the tatties, but what else is in this?
Not tatties. It's Fuhk.
Fuhk is a type of pumpkin. Very delicious.
Looks like a good fuhkn pot of soup to me Mark! [emoji185]
Lol. It was.
Just picked them from a tree - I asked what they were and they said Fuhk - i said wash your mouth out!!! ....
    • Hello and welcome from Leeds.
