Delete account
How does one delete the WRT account?....thanks
You cannot delete an account but we can disable your account - please submit a support ticket to request.
4 hours ago, matabog said:
Now, why would you go and do that?
40 minutes ago, digginstony said:
There's nothing really like WRT on the web. Most sites are "Just look how pretty my watch looks today" why delete your account ?
Sent from my SM-T585 using Tapatalk
Gotta agree with these guys, for what it's worth, I have been a member of several MB's and I would not have stayed at WRT this long, if there wasn't something I could gain from it, even as an amateur repair person, not to mention the diverse personalities and colorful commentary. Your have to admit there is no other site like this and I don't try to curry favor with anyone.
Curry:  to seek to gain favor by flattery or attention
We all get discouraged at sometime or another, when you get stuck trying to do repairs or things in general just don't seem to work no matter what you do. I've wanted to get out of watches altogether a few times but my determination to conquer the seemingly impossible tasks won't let me, maybe it's just me. I do know one thing: you can't be successful at repairs, if you give up. You can PM me with why you want to not be a part of this, maybe I can help change your mind.
Dave
14 minutes ago, matabog said:
Ok, you scared me! :))
But what's the computer resources got with the wrt account? I believe you've been lied to.... by your computer! Kill it! Before Skynet takes control... scarry!
Don't forget to say "Asta La Vista Baby" in a very thick, deep accent
:D
No problemo!
  • Mark locked this topic
This topic is now closed to further replies.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
