Hello from the Pocono mountains in PA.
Hi everyone,
              I've been collecting and restoring Seiko's for about 10 years now. I've also been accumulating tools and equipment to fully service their movements. I stumbled across this forum while doing research on Seiko lubricant's and decided it was a great knowledge base and decided to join up.
Regards,
Tom
3 hours ago, vinn3 said:
welcome to the forum.  if you would, tell us about the problems with that "push button" stem release mechanism,  as several members have had problems with it.  thanks, and again welcome.  vin
If you're referring to the stem release issue on the 6139's, 6138's, and others where the keyless works fall out of position after removing the stem, it's due to pressing the stem release button and removing the stem + crown while the crown is pulled to the time setting position (number 2 position) rather then the crown being in the number 1 position.
Often times you can coax the release button back into position by inserting the stem slightly in the direction of the button and giggling it gently until things line up. If you're unsuccessful then the dial, hands, day + date wheels must be removed to access the keyless works.
19 minutes ago, steve855 said:
Hi Tom! Good folks on here and lots of knowledge. There are some very good pros, and plenty of amatuers like me. You'll notice some familiar faces here I'm sure.
Steve
from Berks Co. PA
Sent from my GT-P5113 using Tapatalk
Hi Steve,
       Nice to see you over here! We still need to get together to share some case refinishing techniques.......:) Been busy all winter so far. Sorry for the delay.
Tom
Hi Steve,
Tom
No problem at all, been quite busy myself. Glad to see you here at WRT.
Steve
