Pivot or jewel
Depends on the tools you have. To reduce the pivot you will need either a lathe or a jacot tool. If you choose to change the jewel you will need a jeweling tool or you might achieve it with a staking tool. Both methods would work.
I have a staking set and a lathe but the lathe is a sherline 4400 I have no experience with either .I am not sure but I believe I need collets for the lathe so I can work on smaller pieces. So I guess making the jewel hole bigger is the way to go.. any suggestions on how to go about it.
Anthony
Sent from my SM-G900T using Tapatalk
I am not sure how to make a jewel hole bigger. There was a post on this forum a while ago doing this job using diamond paste & a Dremel. However getting the size hole correct is going to be difficult. If it was me I would just purchase the correct size jewel and replace.
Looks like it could be  @szbalogh video? He is the master of replacing jewels and repairing pivots?
If i would do it i would replace the jewel? If that is possible? think it would be difficult to enlarge the hole?
As you probably need to set the plate up in a lathe or some kind of device to get the hole perfectly straight?
Edited by rogart63
Looks like it could be  [mention=2058]szbalogh[/mention] video? He is the master of replacing jewels and repairing pivots?
I would rather do one repair or the other replacing parts is to easy..Been there done that.
Lol not, just butchering around :)
Jacot tool should be used to reduce the pivot diameter.
But here i would use the lathe with a wax collet. Just put a small brass rod in the lathe and turn a thin cone, fill it with shellack and put the wheel inside. It can be perfectly centered while the shellack is still hot. Then use a fine hone or steel with diamond paste to reduce the pivot diameter. The file should be supported on the parallel support to keep cylindrical shape of the pivot.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
