FHF 90-5 keyless problem
WileyDave
A good friend of mine gave this watch to me to diagnose/clean. Its a 70's Sandoz 25j auto diver. When I first looked at it the two screws that hold winding bridge down were fumbling about inside the case, so I replaced them in appropriate spots. Then it ran crazy fast, so my first though was magnetized. However, the winding/keyless will not go back into place. The stem and winding wheel are indexed so they will only align when fitted precisely. The crown is spring loaded screwdown, so it's difficult to push stem with appropriate force to make certain it's properly engaged, (in movement). My questions are: Does anyone have experience with these? Am I missing another gear? (are there two)? I have had it (stem) in and winding and setting, but fear I may have lost a part!?! It's not been cleaned yet so any help would be appreciated, Thanks!
That is common that that gear falls out? Happens when you removes the stem and tilt the movement? Also easy to put back again. So no problem there? If nothing else isn't  wrong under there? Sounds like it could be though as the small screws where loose? Someone tried to do something with it? Maybe put the setting lever back by taking of the winding bridge? Instead of removing the dial?
Running fast is probably dirty hairspring sticking together ? Sounds like it needs a service?
Edited by rogart63
Don't believe it's ever been serviced, it was sitting since the 70's, (no marks in back case). You're correct with the tilting of movement for replacement of gear, stem will still not engage even with detent pushed in, just frustrating! The cleaning and demag should end fast running as I recall the mainspring stayed pretty tight with a manual wind and it ran for over 24 hrs. I'll remove winding bridge and check underneath. Thanks for your response. Dave
Think i have some parts if you need anything? pdf you have here? Same movement? http://docs.google.com/viewer?a=v&pid=sites&srcid=Z2xlYXZlYW5kY28uY29tfHRlY2huaWNhbHxneDoxNTZiMTgyM2U5MzY3NWQ1
See in the pdf that someone has written wheel on stem :)
Edited by rogart63
Thanks rogart63, I may have inadvertently tried to replace that part backwards, I also noticed it was sticking to stem, even after cleaning up (magnetized?), perhaps another reason it didn't want to seat down inside, thanks for the parts list, makes it much easier to ID all parts, obviously this is my first stab at one of these and because it's a good friends watch, (purchased on a day trip to Switzerland while on student exchange in France)  So, I don't really want to screw it up!  Again, my thanks, you have been more than generous with the file and offer of spares. Dave
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
