Tweezers advice?
Tcarpilot,
I bought a set of very nice tweezers from an Ebay company called RED ROOSTER UK. I don't know if they still carry the same brand I bought but it might be worth checking them out. At the time I only paid $30.00 for the entire set and they worked great.
david
The brand of tweezers I purchased from Red Rooster UK were called Stella Tweezers. They were very well made and have performed beautifully over the past several years. I also bought a set from Finding King called Moon Tweezers. The Moon tweezers had to be reworked with a sharpening stone in order to get them to work properly but the Stella tweezers worked perfectly right out of the pack. I don't know if Red Rooster still carries that brand or not. The only tweezer I was not able to find a less expensive substitute  for, was the Dumont #5. Other than that the Stella's have worked out just as well as my Dumonts.
david
Most tweezers are designed and manufactured for the medical and dental industries. The angled tips are useful in a restricted work space such as someone's mouth. The world has a lot more doctors and dentists than watchmakers. Some of the tools that watchmakers and jewelers use have been borrowed from other industries.
david
  • 2 months later...
Whilst engaged in another thread a question kept coming to mind but it didn't really belong there. So I'll ask here.
With tweezers do you prefer stainless steel or high quality carbon steel ? Or do people not really care.
My own preference is carbon steel because it will retain its shape well and when "stressed" is easily corrected, which is not the case with stainless
Stainless for disassembly Brass for assembly thats my preference.
I can see why you would do that. Stainless incase something doesn't come out or off the way it should and brass minimising risk of scratches and damaged to tweezers. That's very clever ! I will adopt this myself with my brass tweezers.
Many thanks for your reply
' stressed tweezers !! ' why ? Because in my personal sense, you do not raise a brick or you do not squeeze a piece out of hand? For the sorts of metals concerning the tweezers, I imagine that everyone makes use of what he has provided that they are not magnetised. Finally, if we take care of our tools, I can easily imagine that we should not be forced to twist our tweezers. On the other hand, for screwdrivers, it is different because I saw tons of watchmakers On Youtube that work poorly and do not take the proper size of screwdriver for different screws ... I do not know much about watchmaking but my tools, I take care of it ;)
' stressed tweezers !! ' why ? Because in my personal sense, you do not raise a brick or you do not squeeze a piece out of hand? For the sorts of metals concerning the tweezers, I imagine that everyone makes use of what he has provided that they are not magnetised. Finally, if we take care of our tools, I can easily imagine that we should not be forced to twist our tweezers. On the other hand, for screwdrivers, it is different because I saw tons of watchmakers On Youtube that work poorly and do not take the proper size of screwdriver for different screws ... I do not know much about watchmaking but my tools, I take care of it [emoji6]
In this context it refers to the ability to retain shape under normal and unforseen circumstances.
Cheap steel has no flexibility to return to shape so constant maintenance would be required.
English gunmakers prefer a mild steel (EN21) in their gun barrels! Though this quality steel enjoys a great deal of flexibility to return to shape even when pushed beyond its normal working pressure. Due to faulty ammunition.
German makers tended to use a much harder steel. Though could shatter with fatal consequences when pushed beyond its normal working pressure. This rarely happened .
It's all a question of getting the right balance.
I've used brass and carbon steel exclusively.  The brass tweezers are used about 95% of the time but they require a bit of maintenance since brass is soft and prone to deform.  The carbon steel come in handy for the real precision work but they will scratch parts quite easily and are prone to magnetism.
Eventually I'll expand my kit and probably add a set of stainless tweezers.  I'm hoping there will be a few more people piping in regarding the pros and cons of stainless tweezers in this thread.  :)
Well, now i understand the differences [emoji6]  but but for the watches, no need to stress a tweezers  ....Thanks guys for the reply [emoji6]
You'll find the most experienced watchmaker will need to re-shape (Dress) his tweezers and they apply their craft to this in a most proficient and expert way and is an essential skill that needs to be learnt. [emoji4]
I dress mine every week especially the gripping surfaces I grip a file between the ends and gently move the file this gives the tweezers more grip.
Check this video its very informative.
Edited by Cad101
Love my new Dumont Titanium tweezers? So light. And not that sensitive for bending. Can ping a few screws if you press to hard on them. But once you master that i no problem: Great for working quartz and the don't get magnetic. Bought a 5 and  a 2. Dressed the 5 sharp tip a little as it was like a needle :)
Carbon steel tweezers can be glass-hard. My stainless Dumonts are softer and still get magnetised slightly anyway. I also have their "Dumostar" versions which are very hard, to be fair.
As already mentioned, dressing them is very important, including giving the insides a slightly co**BLEEP** finish to provide grip.
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
