Seiko 7009A
I acquired this movement recently and upon disassembly the spacer between dial and movement. Cracking was observed. My question is because I've had this happen before " is this common to this movement with age ie does this become brittle" Or have I just been unlucky ?
The example shown was fitted with a 7s26 dial that somebody had managed to fit. One of the dial feet appeared to be bent to accommodate this.
When I lifted the dial the bent foot remained in the movement and yes I did position the eccentric cam first.6a9c3f11ea0bf5827cbaf7a096d3b211.jpg
Very common unfortunately? Had they been worked on and fitted with an other dial.
Probably have a few if you need?
Im sure I have a spare dial for this somewhere. I'm not sure what I want to do with this movement. My timegrapher indicates wear. Low amplitude and a scatter pattern when not in the dial up or down position , so something in the escapement is touching. Hairspring looks good and not touching anything.
Movement fitted with a 7s26 rotar as well which is good (gold dust)
Think I'm going to keep it for parts. It's seen better days.
Many thanks though
Sent from my SM-T585 using Tapatalk
The same spacer is used in many older Seiko movements and they do have a propensity for cracking. You can still use them as long as it has only one crack in it and the spacer is still in one piece but if it bothers you nos ones can be found on ebay.
First : How do you know if the spacer is cracked ? the watch you see is my avatar . second : i have it since 3 or five years , i can't say realy but my " 5 " is in working condition.  However, when i received a movement ( 6119C for another old Seiko 5 ) i 've never seen a spacer on it . Is it just on a 7009A ? because it's the movement that i have on my watch and at this day, no problems at all...
I can't really say what particular other movements employ this spacer or to be probably more correct "A 2 piece movement holder"
I do know the later 7s26 movements employ a single movement ring and the dial fits into this as opposed to the movement itself. In my opinion a much improved design.
If on your 5 you remove the movement from the case, you will be able to remove the first movement ring from the rear.
Then you will see the second ring lodged between the movement and the dial. It's function is to allow enough space for the complications to work freely and not jam.
Careful examination even with some magnification, you will see faint crack lines on the spacer.
Hope this answers your question
While Seiko spacers do crack, it is usually because of improper handling and being glued to the movement/dial due to broken dial feet.
Citizen plastic spacers on the other hand.... this 'clicks' positively onto the movement and need to be bent a bit to get them off.. result.. broken spacer. It also takes me a while to figure out the correct way to fit it back. You can mark it near the stem to help you but that's for beginners (ohh alright .. I usually forget!!).
-digginstony, If I may ask, was this from India?
Anil
Anil
The movement was acquired from a car boot sale in a poor state for £10. I do have a couple of other 7009A movements and 1 being in good condition but I lost the day jumper spring when servicing!
So I will exchange the spring from this movement (and be more careful)
Also the rotar is very good so I'm very happy with the purchase.
Tony
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
