Seasoned Professional
I may not have any better suggestions for repairing dial feet, but...what the hell is he doing?!:pulling-hair-out:
I could forgive the method, better to have those 2 points of damage visable on the dial than the dial spinning, but he shows a breathtaking disregard and lack of care to the face of the dial at almost every point of handling it. nope nope nope. I think i need to go lye down for a while now. :D
Edited by Ishima
When watches were first made hundreds of years ago, propane, acetylene and even cross slides weren't invented yet; let alone the torch. Dead center turns were used to make staffs and pivots until live center lathes came onto the scene.
 With the exception of a motorized watchmaker lathe,this watchmaker is using, more or less, traditional tools and techniques. Obviously a dial foot soldering machine or even a torch would leave a smaller impact on the watch dial. My guess is the watchmaker in this video did not have access to these tools yet he repaired the watch with the tools he had on hand and did it in a very skillful manner.
david
If the repair is hidden then I suppose it could be a way. The interesting part for me was how he steadies the piece with the end of the tip over rest. I might try that one. If he had used a song metal glue & did not drill completely through his method would work.
If you watch some of his other videos you can see that he is highly skilled and seems to have years of experience. I would find it hard to be judgemental  toward his approach as I do not know his situation.  Many people in the eastern block countries live under extreme poverty as well as having to deal with political and infrastructure problems. It can be difficult to afford food let alone a bottle of Loctite or a tourch.  I feel that he did well with what he had to work with.
david
Hello David,
I accept totally what you say in respect of the Eastern block countries.
  Jarosław Wilczyński definitely has skills far in excess of anything I, as a tinkerer, would aspire to. I decided to look at some other videos he has put on the tube and was surprised to see that he has indeed got all the modern equipment you would need as a watch repairer and maker. Check out what he was using 4 years ago "Zarta 1800 watch consist" and some of his other videos showing timing machine, parts cleaner etc.
Without, I hope, being judgemental, I feel that he was merely demonstrating his skill in a way to perform a task, perhaps as it would need to be done if you did not have the relevant tools, and in honesty he succeeded from that point of view.  I would guess that he perhaps would not work that way normally and was just having some fun.
The idea of taking a hammer to the front of a dial especially without a fine punch certainly had a shock effect on me. However, even with the two holes he created and covered with white paint the whole demo of his skill was educational. As I said I do not have his skills and would probably have used something stupid like sticky dial pads.
In conclusion, I recommend that people should check out his video on "Omega Seamaster - Cleaning, folding, checking" if you want to see some more of his real skill, he has the most steady hands I have seen and note the attention to cleanliness and care - finger cots included. A talented guy.
Regards,
Vic
David, I don't think they all meant to bash the man for his technique, but only to point out that it was quite unusual. Ok that was an inexpensive Seiko 5 watch, and probably he was just showing an alternative "ancient" method to do that kind of repair, but looking at his other videos, I do sometimes see things that make me cringe sometimes. And I am not a professional watchmaker, just a hobby watch repairer... So my opinion is to be taken for what it is worth: almost nothing.
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
