Balance Question
Pip
I have had a slight mishap with the balance on a Seiko 6309A that I am practising on, and have managed to pop off the diashock assembly. I can see from the tech guide how it fits together but can't quite work out how to actually do it; not sure how to line it all up and then how to refix the diashock. Is there a particular tool or method best used for this? Diagram below should explain what I mean.
Thanks as always,
Pip
If you search "diashock" in this forum you will find a lot of threads with hints.
Also please give a look to some parts naming document, because isn't clear what you mean.
It also  helps to watch some videos, of course Mark's ones are very good.
Edited by jdm
If the 3 parts you circled are in one unit, i would separate the bottom two (chaton and jewel) from the top one (spring)
place the chaton and jewel assembly on the balance cock in the hole. It is easier to do that with the balance cock installed in the movement. The assembly should fit nicely on top of the balance staff., with the pivot going into the chaton.
then lock the assembly in place with the spring. Be careful, the spring will ping at any opportunity! It may be prudent to locate the spring on the chaton/jewel assembly using rodico to avoid losing it. Then you just need a steady hand to rotage the spring into place, i use 2 pairs of tweezers, or one pair and a sharp pegwood. There are 3 "arms" on the spring, they all need to go into the groove in the cock which is located around the chaton/ jewel assembly.
i usually insert 1 arm when i place the spring on the assembly, and then rotate the spring to fit the other 2 arms in the channel, pushing gently on the arm i want to fit in the channel whilst rotating the spring.
hopefully i have interpreted your question correctly and the above is of help!
good luck with it :)
Edited by oli
Thanks guys for the great answers. @ftwizard and @oli I think you've cracked my problem that I struggled to explain well. I will follow the advice and I've read somewhere (this forum maybe?) that when one is a beginner as I am that when manipulating diashock springs, do so inside a large clear plastic bag where possible to prevent it leaving the earth's atmosphere.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
