Stakes jam in K&D staking anvil. Suggested repair?
By OceanSprint · Posted
Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks -
C07641+ not sure what the "+" is for after the last digit.
Thanks again, Dell. I'd already enjoyed your set of 8 YT videos! Photo attached.
By MartinOfPrague · Posted
All right, so here is the most likely explanation: one of the dial feet is broken off, therefore the the dial is not well centered and the short tube which is a part of the hour hand probably rubs against the edge of the dial hole. Thanks again for all the suggestions, though!
