Watch magnetism and demagnetizer
Very interesting and very useful. I can't find the specific one you show in the video, but I found a different EMF app (free so maybe quality is questionable) just now and tried it out on my watches. I am seeing that anything metal is causing some kind of signal change, albeit weak. Any suggestions as you seem to have yours dialed in to the point it doesn't move at all when the watch is put near the compass.
Maybe I am not properly using my demagnetizer. It's just a cheap Chinese version. I begin with the object at a distance, turn the magnet on, slowly being the item into the magnetic field until it starts to buzz then slowly remove the item until it's an arms length away from the mag. Either way I ran a few tests and maybe you can help me interpret. So first off here is just a spring bar tool that I had laying around that came with a strap recently:
I then magnetized it using my mag and got:
Then followed the procedure that I spoke of at the beginning to demagnetize. My reading afterwards was slightly lower magnitude than before but still noticeable:
And then comes a watch that I just demagnetized following the exact same procedures that appeared to work for the spring bar tool, but repeated 2 times in 2 different directions.
I am afraid maybe you are right and that my demagnetizer is too weak to demagnetize the whole watch all at once. And that I will haves to demag each part individually. Appreciate any feedback you can lend.
Yes it seems to me that the demagnetizer You have is strong enough for the spring bar remover but not strong enough for a whole watch.
3 hours ago, thessler said:
I have a question though , if the watch was demagnitser two months ago Im  wondering why it is magnetic now ?
The answer is in the description. I am working with a strong magnet at my workplace :)
I appreciate it. I will have to try and demag the movement itself and see if that helps, if not I guess I will being doing it by each individual part.
What is the app you are using?
It is Teslameter pro on the iPhone. It says it's a "metal detector" but I assume that it can serve the same purpose with maybe just a small amount of static.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
