Watch magnetism and demagnetizer
Very interesting and very useful. I can't find the specific one you show in the video, but I found a different EMF app (free so maybe quality is questionable) just now and tried it out on my watches. I am seeing that anything metal is causing some kind of signal change, albeit weak. Any suggestions as you seem to have yours dialed in to the point it doesn't move at all when the watch is put near the compass.
Maybe I am not properly using my demagnetizer. It's just a cheap Chinese version. I begin with the object at a distance, turn the magnet on, slowly being the item into the magnetic field until it starts to buzz then slowly remove the item until it's an arms length away from the mag. Either way I ran a few tests and maybe you can help me interpret. So first off here is just a spring bar tool that I had laying around that came with a strap recently:
I then magnetized it using my mag and got:
Then followed the procedure that I spoke of at the beginning to demagnetize. My reading afterwards was slightly lower magnitude than before but still noticeable:
And then comes a watch that I just demagnetized following the exact same procedures that appeared to work for the spring bar tool, but repeated 2 times in 2 different directions.
I am afraid maybe you are right and that my demagnetizer is too weak to demagnetize the whole watch all at once. And that I will haves to demag each part individually. Appreciate any feedback you can lend.
Yes it seems to me that the demagnetizer You have is strong enough for the spring bar remover but not strong enough for a whole watch.
3 hours ago, thessler said:
I have a question though , if the watch was demagnitser two months ago Im  wondering why it is magnetic now ?
The answer is in the description. I am working with a strong magnet at my workplace :)
I appreciate it. I will have to try and demag the movement itself and see if that helps, if not I guess I will being doing it by each individual part.
What is the app you are using?
It is Teslameter pro on the iPhone. It says it's a "metal detector" but I assume that it can serve the same purpose with maybe just a small amount of static.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
