Seiko Turtle
digginstony
Price for these dropped considerably since introduction, which is just right since they were overpriced to begin with. And don't  get me started on about the LE / PADI ones which have so many drooling for. Well done Seiko for pulling a profit with few touches of color and a nice box.
Mine say hi
Edited by jdm
