Omega 1010, low amplitude
mikepilk
I've just finished cleaning an Omega 1010 and I'm only gettting about 230° amplitude.
This is the second 1010 in my collection, and with the first one, I only got about the same amplitude.
For lubrication I used :
9010 on the balance,escape wheel and fourth wheel,
9415 on the pallet jewels,
D5 on the rest of the gear train (including the centre second pinion).
The spring looks good. All the jewels and pivots looked OK under a x10 Loupe.
Is anyone familiar with this movement and know what I've done wrong or what I should be looking for ?
I plan to have a  look at the jewels/pivots under the microscope - should have done it initially !
Well the most obvious culprit would would be a played out mainspring, otherwise it sounds like you're looking in the right places.  I'm not sure if you have already but you might want to let it run for a bit- I usually give it twenty-four hours after assembly to let the oil settle/distribute before looking for an accurate reading on amplitude.  Then I'd check the following:
  1. Cleaned and properly lubricated jewels & bushings
  2. Bent or lopsided pivots
  3. Worn bushings, broken or cracked jewel settings
  4. End shake on all wheels
With Incabloc protection you'll also want to make sure the top and bottom cap jewels on the balance haven't been swapped- they aren't always the same thickness.
Edited by RyMoeller
Spelling
D5 is kinda thick, not to mention is natural oil with a shorter life, synthetic would be better. I would use 9010 on everything that moves from the mainspring. That made a difference for me. Anyway, even 230' is plenty for the mov.t to run strong and accurate. And you also have to look at the overall pattern.
Edited by jdm
Over-oiling the pallets can reduce amplitude. I presume by spoiling the impulse.
If you have a timegrapher, how was the amplitude in vertical positions such as pendant down and pendant left?
You can live with lower amplitude as long as the escapment is well poised. If it isn't, then you'll get progressively worse positional variation as the watch winds down which could become problematic.
6 hours ago, mikepilk said:
Can too much oil (it's not sloshing around!) have so much effect?
Yes, a liberal application of oil will have an effect on amplitude.  As @clockboy stated though, in my book 230 would be acceptable- especially if I felt I may have gone a little heavy on the oil.
Edited by RyMoeller
I can live with the 230 - the watch will only get the occasional outing.
I was more interested as to why.
I've spotted one problem. The auto mechanism isn't jewelled and one of the pivot holes is oval. I can see the pivot waggling round if I manually wind it.
Are the brass bearings machined in, or pressed in replaceable parts ?
Bearings on trainwheel bridges are often a culprit for low amp? At least on Seiko. Think the Omega 1010 is about the same construction with the bushing directly in the brass . Check for excessive movement in the barrel?
Edited by rogart63
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
