Do you remember your first time?
Pip
A bit of a moment for me today - officially resurrected my first dead watch! Not exactly a sought after classic, a defunct Seiko quartz V657-7100 that I got off the bay for a few quid. Not working, crystal that was too knackered to see through and full of crud. I took out the movement and gave it a bit of a sloosh, new battery, changed the crystal (first time for that too, loving my new screw down crystal/case press) and gave it all a bit of a polish with some Cape Cod. Although movement was officially working a day or so ago I've been waiting for the press for reassembly - my official timeline stopped when I got it all back together. Bracelets too **BLEEP** small though! And looking at the pics I may have to pop the crystal and align the bezel again.
But I'm a proud puppy. Woohoo! Onto the next one...
On 2/25/2017 at 3:02 AM, ricardopalamino said:
Any idea yet what your next one might be ???   Keep us posted and good luck .
Well at the moment Louis I have a couple of non runners on the go that are in the parts tray while I try and work out what's wrong, a Bellmatic (that I'm about to start trying to learn to remove rust from the movement) and a Seiko 66-6000 on the way that I have no idea what's wrong with it but is described as non working. And unfortunately I have the builders in so have lost half my house and most of my time, so not much chance to practice. Spending most of my time researching and reading.
Wow , If you are ready to attempt a service on a bellmatic my hat's off to you and I wish you good luck . I have never really been a Bellmatic fan , but it just so happens  that I picked up a free donor yesterday that has broken parts but a beauty blue dial and the original band .
  This watch has seen better days , but i picked up a running watch, head only , that is the same case as the non-runner . I hope to get one nice runner from the 2 watches .
I guess I was on a Bellmatics roll because I also picked up this Nice running specimen for a good price . It needs a new crystal that I am in the process of getting , but it has a coffin link Bracelet that I'm a sucker for . I have a coffin link on my Bulova Accutron Astronaut and I love it .
58b4c206715ce_ScreenShot2017-02-27at2_11_16PM.png.477aabf74e101786ee65d0b17b69ccb2.png
58b4c22ec0e47_ScreenShot2017-02-27at2_11_28PM.png.f715da7a4b038f867e7fb1e31dff4dd7.png
58b4c25115b5c_ScreenShot2017-02-27at2_11_41PM.thumb.png.d353dbf35c0d9910a97f75a6c0aad7ba.png
Do you have the Bellmatic / 4006 tech sheet ? It's quite long and involved and you may want to study it before you start your project .
If I'm not mistaken , the Seiko 66 morphed into the 6602 which tech sheets are also available .  You can go to the Seiko Citizen Watch forum and find those tech sheets and many other things Seiko and Citizen .
Yes, BM's are very complicated I've read, but then one I have is junk at the moment so I can't make it worse. I have the tech guides and have also studied (and made a book of) the teardowns on another site so will be as prepared as I can. I've also just ordered the movement holder from Adrian, I figure every little will help!
Wish me luck...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
