From Russia with love...and sand!
This is the second Poljot 3133 Chronograph I received, from which I already took the balance wheel to temporarily fix the Sturmanskie on the other thread (when the new balance wheel arrives I will swap them again).
This one looks pretty sad, the case gold plating was badly worn of and the movement, without the stem, makes me think the watch took a plunge in the Baltic Sea, so much sand is inside!
Edited by GeorgeClarkson
The order was inverted by the phone... But you get the idea. All the parts were cleaned and inspected. I found no broken jewel nor bent pivot, only a lot of sand and dirt.
The chronograph start/stop lever was damaged though, so that will need to be sourced. A pic I took before disassembling the movement shows the broken off tip of the lever, where the pusher should touch it.
