Eagles table top clock by a C.Amadei
GeorgeClarkson
A couple of years ago a very old lady living next to us ( she was 90) and with whom I was befriended and took care for together with my wife (relatives basically abandoned her to live alone in that flat, bit she was almost self sufficient) passed away after a couple of weeks in the hospital, but before she was gone, she presented me with her clock, a 2 eagles wooden clock signed by a C.Amadei that needed some love, just like her.
I have never heard of C.Amadei but I expect its who made the case. From what I can see at the back the movement is a 30 hour movement with a balance wheel it might be 8day but I doubt it, the type of movement you would expect to find in a case typical clock insertion movement. I don't now if this type of movement is made today, back in the 70's and 80's you could buy replacement movements to fit for a few pounds it even included dial, hands and back plate. To remove the moment, undo the key and pull the hand set off, undo the nuts and pull the movement out. The pallets will be of the pin type. This is the type of movement I would start an apprentice with, simple and easy to understand. Sorry you don't have a Thomas Tompion.:D
The movement has already been service 1 year ago actually, i made photos but never posted them, was too busy and not my focus, I will post them next week.
I opened this thread now since I noticed that it has staffed to run fast, it gained 15 minutes in 12 hours.
I installed an app on my mobile, not a timegrapher, but gives an approximative idea. Here the screenshot
Could the clock been exposed to any magnetic force. Must be worth a look at the hairspring to see if any "Crud" has found its way between the spring coils?
The carving on the case looks really nice. Could it be French or Austrian with those eagles. Looks Frenchy to me ?
Sent from my SM-T585 using Tapatalk
That is what I expect to see, looks like a 30 hour movement. With this type of balance staff they tend to lose their point so the action of the balance can be poor, so the balance is put into a lathe minus the hairspring and is sharped into a point on both ends, sometimes with lack of oil the cups wear and have to be repaired or replaced. The hairspring should bounce in the regulator from one end to the other in order for the regulator to work properly.
The 1 minute you see on the screenshot is not real, it was still adjusting when I took that screenshot, then had to leave the room since my baby daughter was calling.... When I returned, it had settled around +4 minutes, but with a baby on the hands it is hard to mess with the mobile to take a screenshot.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
    • Hi wathweasol. I think it's made of brass. From the look of things, replacing the whole pusher as a set is beginning to be the way to go. Thanks. I'm thinking it could be just a tube and friction fit. I've taken another shot of the tube and posted here. Looks like just a tube fitted flush. Then, again, I have no experience in chronographs especially tubes and pushers. This one has no clips or washers to lock in the pusher in place. Coming from the outside, you'll have the button, spring and the stem inserted from the case and screwed in. The case holds the spring in place and the ridge at the other end of the stem keeps it from falling out of the case. Posted some pics here and an illustration to help. My sketch of how all the parts come in to play: Two different angles of the stem. Note the ridge near the slotted end that stops it falling out. This is an assembled piece of the one that was successfully pulled out. If it will have to be replaced, may I have some tips please on how to place an order, sizing, etc (Cousins, Esslinger,...) and on how to remove/install the pushers. My experience is just basic service with time only, day/date complications. Haven't had the opportunity to replace crown tubes and pushers. Thank you so much.
    • If you have no Powerpoint at Hand (but Libre-Office or whatever..), to get Access to the Videos in the pptx, make a Copy of the File, rename it to blabla.zip and unzip the File. Now in the Folder ppt/media you have all Pictures and Videos......   hope this helps some of us regards, Ernst
