Eagles table top clock by a C.Amadei
GeorgeClarkson
A couple of years ago a very old lady living next to us ( she was 90) and with whom I was befriended and took care for together with my wife (relatives basically abandoned her to live alone in that flat, bit she was almost self sufficient) passed away after a couple of weeks in the hospital, but before she was gone, she presented me with her clock, a 2 eagles wooden clock signed by a C.Amadei that needed some love, just like her.
I have never heard of C.Amadei but I expect its who made the case. From what I can see at the back the movement is a 30 hour movement with a balance wheel it might be 8day but I doubt it, the type of movement you would expect to find in a case typical clock insertion movement. I don't now if this type of movement is made today, back in the 70's and 80's you could buy replacement movements to fit for a few pounds it even included dial, hands and back plate. To remove the moment, undo the key and pull the hand set off, undo the nuts and pull the movement out. The pallets will be of the pin type. This is the type of movement I would start an apprentice with, simple and easy to understand. Sorry you don't have a Thomas Tompion.:D
The movement has already been service 1 year ago actually, i made photos but never posted them, was too busy and not my focus, I will post them next week.
I opened this thread now since I noticed that it has staffed to run fast, it gained 15 minutes in 12 hours.
I installed an app on my mobile, not a timegrapher, but gives an approximative idea. Here the screenshot
Could the clock been exposed to any magnetic force. Must be worth a look at the hairspring to see if any "Crud" has found its way between the spring coils?
The carving on the case looks really nice. Could it be French or Austrian with those eagles. Looks Frenchy to me ?
Sent from my SM-T585 using Tapatalk
That is what I expect to see, looks like a 30 hour movement. With this type of balance staff they tend to lose their point so the action of the balance can be poor, so the balance is put into a lathe minus the hairspring and is sharped into a point on both ends, sometimes with lack of oil the cups wear and have to be repaired or replaced. The hairspring should bounce in the regulator from one end to the other in order for the regulator to work properly.
The 1 minute you see on the screenshot is not real, it was still adjusting when I took that screenshot, then had to leave the room since my baby daughter was calling.... When I returned, it had settled around +4 minutes, but with a baby on the hands it is hard to mess with the mobile to take a screenshot.
    • It's pronounced "bombay" like the city.  French for bomb is, 😄, bombe, pronounced the same as in English. Bombé, bombe.
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
    • I have quite a few watch brands from all over the world. For some reason this Timex electric from 1979 is capturing my attention this week. I am not a particularly fond of battery operated watches or Timex, but this one is different for some reason. Post your watch in your collection that seems to draw you in more now than before...
