Eagles table top clock by a C.Amadei
GeorgeClarkson
A couple of years ago a very old lady living next to us ( she was 90) and with whom I was befriended and took care for together with my wife (relatives basically abandoned her to live alone in that flat, bit she was almost self sufficient) passed away after a couple of weeks in the hospital, but before she was gone, she presented me with her clock, a 2 eagles wooden clock signed by a C.Amadei that needed some love, just like her.
I have never heard of C.Amadei but I expect its who made the case. From what I can see at the back the movement is a 30 hour movement with a balance wheel it might be 8day but I doubt it, the type of movement you would expect to find in a case typical clock insertion movement. I don't now if this type of movement is made today, back in the 70's and 80's you could buy replacement movements to fit for a few pounds it even included dial, hands and back plate. To remove the moment, undo the key and pull the hand set off, undo the nuts and pull the movement out. The pallets will be of the pin type. This is the type of movement I would start an apprentice with, simple and easy to understand. Sorry you don't have a Thomas Tompion.:D
The movement has already been service 1 year ago actually, i made photos but never posted them, was too busy and not my focus, I will post them next week.
I opened this thread now since I noticed that it has staffed to run fast, it gained 15 minutes in 12 hours.
I installed an app on my mobile, not a timegrapher, but gives an approximative idea. Here the screenshot
Could the clock been exposed to any magnetic force. Must be worth a look at the hairspring to see if any "Crud" has found its way between the spring coils?
The carving on the case looks really nice. Could it be French or Austrian with those eagles. Looks Frenchy to me ?
Sent from my SM-T585 using Tapatalk
That is what I expect to see, looks like a 30 hour movement. With this type of balance staff they tend to lose their point so the action of the balance can be poor, so the balance is put into a lathe minus the hairspring and is sharped into a point on both ends, sometimes with lack of oil the cups wear and have to be repaired or replaced. The hairspring should bounce in the regulator from one end to the other in order for the regulator to work properly.
The 1 minute you see on the screenshot is not real, it was still adjusting when I took that screenshot, then had to leave the room since my baby daughter was calling.... When I returned, it had settled around +4 minutes, but with a baby on the hands it is hard to mess with the mobile to take a screenshot.
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
