Which watch lume to buy?
Tmuir
I'm about to place an order with Cousins to buy some tools and oils / greases and was thinking about buying a Bergeon green lume kit as I've got a few watches that are cheap enough for me to practice reluming on, but whilst doing some reading up on reluming hands today I came across a number of references Super Luminova with a few of them listing it as superior to the Bergeon Lume.
What does everyone here think?
Should I just buy the Bergeon Lume kit, or should I source from else where the Super Luminova lume kit?
Thanks
Tony
Thanks everyone. I got the response I was kind of expecting, everyone has their own preference and there is no one clear better lume.
I'll get the Bergeon lume since that is what Cousins sell and I will be placing an order with them tonight anyhow.
i bought some lume from an ebay seller a while back. i am reasonably pleased with the lume quality, but the binder has an objectionable smell. chemical smells usually won't bother me, but this does. i hate working with it. what i've been thinking about using is UV activated nail polish. it won't harden until exposed to UV light - which is sunshine.
Tried all. Nitrocellulose nail polish, UV nail polish and akrylic lacquer. All are good but the nitrocellulose nail polish is convenient to use.
Never bought a branded (expensive) lume paint but it would be nice to see a side-by-side comparison of sample spots made with the same binders and solvents in the same amounts. I have brought my relumed watch to a local watchmaker to compare its lume with a good lumed watch. It was a TAG Heuer F1. The initial brightness was about the same, but the most interesting would how the brightness changes with time.
Could You or someone else make this comparison? I dont want to buy that expensive set just for this :)
Humbrol Matt or Satin model paint is what i use? Tried some acrylic paint but i think i dry out to fast?
I emailed Humbrol a while back asking for a Matt lacquer that dried slowly.
They replied with this..
Humbrol AC5601 Modelcote 28ml Matt Cote.
Humbrol AC7501 Enamel Thinners 28ml.
My local model shops don't stock it so I never got round to try it.
Sent from my Honor 5c
I personally do not like the luminous powder from Bergeon that Cousins sell - It looks way to green in daylight - "mint green" instead of the white colour most powders have!
I use lume on routed watch dials and like it when the particles are 2-3µm instead of the standard 10µm - or the surface gets scratched in the process when making dials. The smaller particle size also makes reluming  hands much easier, so if you can - get a powder with a small particle size!
That is not true. The bigger the particles the brighter the lume at night. Moreover, particle size has a great impact. Yes it is harder to work with bigger particles, but if one gets to the appropriate mixture of binder, solvent and powder, then the result will be much much better. I have used the 30-70 µm batch. Ordered some sieves from the ebay to get four sizes batches.
Quote
....and I never stated that smaller size had better lume - I do not know where you got that from!
BUT smaller particle sizes are much easier to work with, you get a better finish and in my case - it is crucial for getting the work done at all.
Neither have i? Use this small cans? Not sure why they are packed in Sweden? Or why we in Sweden have special cans? Or if the paint are the same as in England or the rest of the world? DSC07647.JPGDSC07645.JPG
Edited by rogart63
  • 6 years later...
I don't have a great deal of experience in luming hands, and am watching this thread closely to see which lume you guys recommend. Can anyone let me know where I could buy Super Luminova and the approx price, compared to the Bergeon?
On the subject of binder, I watched a YouTube video of the Nekkidwatchmaker (of course I can't find it now to supply a link) and he used a method where he used 50:50 mix of IPA glue (the white glue your kids use at school) and water as the binder. I tried it a few times with good results, the IPA dries clear so the final lume powder colour is unaffected. As IPA glue is "cheap as chips" its worth a try with some spare hands etc. to gauge the results for yourself, I would be keen to hear if anyone else has good results also.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
