New case for AS1674
ebay purchase movement, which is OK, except the second hand post was missing. Probably why sold as spares or repair. Also have found one of the dial screws is missing
Fortunately tracked the movement down on www.ranftt.de and then on www.oldswisswatches.com, and tracked the movement down as an AS1674 and luckily found the part on ebay (the part cost more than the movement!!)
Case will be 3 pieces: case back with movement holder, case body with lugs, and bezel. Raw materials;
Case back with movement holder in brass. 2 pieces of 3mm brass sheet to get the thickness
Case body will be steel tube, with brass lugs silver soldered on. Plan  to blue the case body to see how it looks against the brass. Bezel will be polished mild steel
The picture just shows the second hand post in in place and movement seems to be working fine (not cleaned)
Left to do is bezel, dial, dial markings, hands, glass and crown - fingers crossed!!
  • Like 5
You have the patience of a saint and the hands of a master craftsman.
I'm not easily impressed, but this is so far over the top, that bluing just "pops" off the brass, solid movement as well.
You should (and will) be proud of your work and skills, Top Drawer!
Dave
Hi Watchtime, yes it is heating polished steel. It is not permanent so not really suitable for a watch case, but this is playing. Towards the end of the project I will spray with laquer to see how that improves the durability, and also it will help seal the brass
  • 4 weeks later...
A bit more progress. Should be able to get a few more hours this weekend to get the hands finished
4.jpg.12ad89ef476997504136db5c63157214.jpg5.jpg.7bdebe9057f9ea8c62406da79ab6659a.jpg6.5.jpg.259e4a2ed5b9c1a751f1bdfdf5478ceb.jpg6.jpg.d38a6caa7f8e98edf9a3c0b11235d2eb.jpg8.jpg.ca48e3b39c88336225d595bfe92daaa8.jpg10.jpg.58c417152d7df692a938f07ddf64ecad.jpg11.thumb.jpg.09ef39b1cf586bc7a7e10235b0d9386b.jpg12.jpg.6d5ded08369709c9ffc752cfcd39ef04.jpg13.jpg.7c9f9b0dc6742e4c2f3e721cffa816a5.jpg14.jpg.0da13de9b54ad798e58067c6dd7e1a14.jpg15.jpg.7b53a6b3db5bdaece39ce74ad58b8a0f.jpg8886.jpg.c2f55ddaf5bf630a6e6ffaf5cb32b473.jpg8887.jpg.4da33b160b49c031443e298070648c25.jpg8888.jpg.0c64fe9bcc7e5f53b4d12d771c1dafc8.jpg9911.jpg.ec8e24a83608cd282278202c0408dfaa.jpg111111.thumb.jpg.627f242cd525da2be01460c4fda64ddc.jpg
Edited by Michael
pictures all loaded twice
This project has got to the stage where I am getting glad it is over. Anyway, crown made, parts sprayed with clear laquer, acrylic fitted and strap fitted. A few other problems I had to deal with to get the watch keeping regular time. The watch now keeps good time and I will regularly wear it and see what snags come up (which I am sure they will !!)
58b206963b926_IMG_4020small.jpg.f744403d830fd2035b0988bb7a4aaba7.jpg58b2069b9905a_IMG_4018small.jpg.d0fad549491cfe23090a85c74ddc2ef1.jpgIMG_4031small.jpg.d0dd210d8424722acd8e23d8536750ac.jpg58b206a1bf156_IMG_4016small.jpg.0f37936852587460cba28e7468c1d1de.jpg
  • Like 7
    • The problem sounds very much like what might happen when failing to do the reset procedure. The stopwatch not working could be a few things.  There are two different motors, one for the center sweep seconds and one of the minute counter.  Damaging a coil is the most likely thing to do wrong when changing the battery, but that would likely just take out one of the two.  So "start" it wait and see if the minute counter doesn't tick over.  If that ticks, and you've done the reset procedure, it's probably damage to the sweep second coil. If neither works, then it could be the button contact is damaged.  It's a tiny bit of copper trace on the PCB that curls around the edge to make a circuit and it can break off.  There's a way to trigger the buttons from the small pads on the back of the movement, as well as check them with a multimeter, if you are familiar with one. But give this a try, pull the crown out to the second position and hold down button "B" (10 o'clock) for a few seconds.  This is suppose to spin the minute counter to let you reset it to 0.  If it doesn't move and (I assume) button 'A' (2 o'clock) doesn't start the chronograph, then either both buttons have failed at the same time or there is something else wrong. A leaking battery can take out the traces on the circuit board, and this can take out the motors and/or buttons, but you didn't say anything about it and it should be obvious if it leaked enough to do that.
    • Perhaps not where you live, but here in DK, you get by the taxman financially quartered if you order from outside the EUSR. These center wheel weren't that expensive 5 - 7 years ago, around $45-$50. I guess stock is drying up and these days we have to pay with worthless confetti money.
    • A little cleaned up, don't think I will polish the brass. Nice caramel color I think. Looks like the inscription says: Ludwig & Fries Frankfurt A.M.  The lanterns were a little tweeked but able to gently flatten out with no breaks. The 6 and 7 pivot beds are broken but the rest of the beds are intact. Box and velvet a bit rough but still functional. Overall nice and just a bit larger than the one above. Why I need 2 I haven't figured out yet...
    • Good job! Wear it well.. .
