Bad start to 2017
clockboy
It,s was my fault I left my workshop ajar last night and found our cat asleep on the window seal this morning. Had a quick check around the bench and nothing was broken and looked ok then !!!!!! I stepped on this wheel. It is from a very cheap (wife paid £5 for it at a fair) Enfield Smiths westminster chiming clock. I have posted a couple of pics of me trying to straighten the pinion and it is almost straight but I can not see how I can rivet the wheel back on as my punches are not deep enough to fit over the length of the pinion. IMG_1046.jpgIMG_1047.jpgIMG_1053.jpg
Good idea Mark yes I have one so I will give it a try. Getting the shaft absolutely straight will be the next challenge
What fun !!!!!
Lol
Good luck - I have every confidence you will repair. :)
Here's another idea, create a larger seat for the wheel.
Make a brass collar that you secure onto the arbor that has a wheel seat centered over the old position. The seat itself will be larger in diameter than the old seat to give it strength. Secure it with locktite. Chuck up the arbor and turn a new seat and a decorative back end.
Once its made  mount the wheel in a pot chuck to open the center hole to fit the new seat diameter. Stake it on normally.
Al Takatsch
2 hours ago, oldhippy said:
Can't you drill the stake out. Its a very common movement as you know so there shouldn't be a problem.
I did think of that but I presume the stake will be hardened steel. I have found some Clock punches in various supply houses wondering if the holes are deeper to allow for the pivots.
Al Takatsch
Thats also a good idea but will I have the issue when staking the new seat i.e. the pinion is to long for my punch.
Well I suppose I could but the stake has to be domed & hardened. This is possible but a big job for a clock that cost £5. However if I can get the pivot absolutely straight I will try to solder the wheel onto the pivot.
Family commitments for the next few days but will keep you guys informed of the progress (if any!!)
7 hours ago, altaka said:
I have a lot of Rebarb steel used to strengthen concrete. 1/2 inch would do it and its soft. It will turn quick in a lathe.
Do not need to harden it because you are staking brass to brass
Al T.
Thanks family commitments stopping progress for a couple of days. Lots of options suggested with this but the priority is to get the pinion absolutely straight because other issues will surface if not.
Al T.
Don't you mean rebar steel.
Just an update with this. I just could not get the pinion perfectly straight & also I found the wheel was also out of true. I did a an experiment for future reference & soldered the wheel to the pinion which works a treat so a useful exercise.
However I have now purchased a donor movement for the replacement wheel.
What fun!!!!
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
