Subscriber Benefits
Hi
I had subscribed at $25/month for a couple of months but I didn't see any real benefit to doing this. I think, at the very least, there should be a confirmation/welcome or some kind of monthly newsletters for subscribers - even if it's just a list of what you can do as subscribers. The only actual confirmation I got was from PayPal. Of course, I was able access places I had not been able to access before but I only found out this by accident one day.
I guess I just didn't get anything out of it; my fault entirely in all likelihood.
Dave
Hi Dave,
I am sorry it's not for you but really, I genuinely cannot see how I could make the Subscriber benefits more clear. Both on the signup page and the individual pages encouraging membership.
If I could be more clear then please let me know as I do not want to cause offense to anyone ...
Hi Mark
I plan to subscribe again.
Is there a separate "Members" drop down menu? I can't remember one. If not, that might be a good idea. It would be a constant reminder of membership benefits with separate headings clearly defining what is available to subscribers.
I seem to remember membership headings were placed at the bottom of the page.
Anyway, that is my suggestion.
Dave
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
